Reset stamina mode, Improve the battery
Erik2017
Hello everyone
Just wondering if there is way to reset stamina mode on marshmallow like in previous visions of Android, as I was able too do it on kit Kat on my z1, but there are no way I can see doing it, without doing a reset,
The reason I want it reset is because may battery is not last a day anymore (14 hours max)
And thats with stamina mode on aswell
I don't use my phone mostly msging, video messages, I do use chomp sms, I don't know if that's causing it
Am I best to wait for next version on android or do a factory reset?
Currently using z5 premium
Thanks
profile.country.RO.title
_alexdon_
@Erik2017 What you can try is this: make sure to turn off stamina, go to settings - apps, tap on 3 dots to show system. Scroll down to stamina mode, force stop it. Then under storage tab, clear data. Force stop your device with power button and volume up at the same time until you feel 3 vibrations. Turn the phone back on. Stamina should now learn and estimate the battery life from the beginning.
alexdon
6 REPLIES 6
CameronT
Hi @Erik2017,
I am not sure what you mean by resetting Stamina Mode, could you elaborate?
To turn it on and off, this can be done from the Quick Settings menu, or from Settings > Battery > Stamina Mode.
To help us identify what may be happening with your battery use, can you please go to Settings > Battery > Show Battery Usage and take a screenshot to post here?
_alexdon_
alexdon
Erik2017
@ alexdon you legend, wish I knew this before thank you so much Slightly_smiling_Face
CharlesJ
Wow! I just did what alexdon said.... Previous to that, battery on 75% shows an estimated of 18 hours of life, which in the cruel reality, was like maybe 8 or 10.
But after reseting the stamina mode on Settings > apps > show system and clearing the cache now the battery is showing an estimated of 1 day 20 hours of life.
I'll see how that turn out. Thanks alexdon!!! Kudos for you!!!
CharlesJ
Well, I have to say this... So far so good! I did a reset on the stamina mode and cleared the device cache. Right now, after 1 day and 2 hours I still have my phone at 28%, of course, with moderate use. Thanks again alexdon!!
Tags (1)
_alexdon_
@CharlesJ Great news.
alexdon
