reboot while charging
D33ZLE
I cant charge phone its keep tebooting
When I plug-in charger,  the red light turn on and the phone start nunnig it  self but not completely just the sony logo shows then reboot it self.and continuously rebooting that way.
Emil
Enthusiast
Hi @D33ZLE,
I'm sorry to hear this. Slightly_frowning_Face
Does this only happen when you try and charge your device? If you disconnect the charger can you start your device as normal?
I would recommend that you try charging your device both using a wall socket charger and a computer and see if you get the same result. I would also recommend that you try a different charging cable to make sure it isn't causing this behavior.
You can also reboot your device to safe mode to see if this behavior may be caused by one of your downloaded apps as these will be temporarily disabled in this mode.
Let me know how it goes! Slightly_smiling_Face
