I bought Z3 last month. I oftenly used Radio app. But it is not working last one week. I restarted. But its not working. Donno why.
Can anyone assist me? otherwise I need to go service center ?
Please help me asap.
Regards,
Babu S- Chennai
I believe you need your headphones connected unless you have modified it so you don't - If you do have them connected then consider performing a system repair
This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
I would also suggest performing a backup of content before the software repair process, as this will remove all your data.
This is done within PC Companion under Backup & Restore
Now its working fine.
What I did,
I just backup my content and update with PC companian. I did after posted this discussion. Sorry for the late reply.
Anyway thanks for the support guys.
