proximity censor does not work when i received phone calls. But when i answer the call the sensor works. I had this issue from the day i bought this mobile. Is this intentional? Any advice would be helpful. TIA.
Oh, I'm sorry I misunderstood you.
It is as you say intended to do so and as far as I understand its not possible adjust.
I suggest that you to run your phone in safe mode for a while to check if you still experience this. If not this may be caused by any downloaded application.
How to boot into safe mode?
If not caused by any downloaded application, I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
I have the same problem, very disturbing to explain to customers that the proximity sensor has some issue that is not repaired in updates! I found out today that during a call, the proximity SENSOR DOES NOT WORK WHEN THE PHONE IS TILTED 45DEG OR MORE, like you often do when the phone is on your shoulder and you press it against your ear. Please, anyone, how can this be fixed? My proximity sensor works fine in all angles when testing, but during a call it doesn't work when the phone is tilted - is there a connection to another sensor during a call?
