hello all, I just got the Z3 and am having an issue with my contacts. When I go to select a contact to call it displays the fax number as default to call. Is there a away to change that? It does it for all contacts that have a fax number, the Phone icon shows up beside the fax number.
thanks for your help
Tried going to edit, but once there any idea what to do?
ok got it! thanks, i did not realize you press the number you wish to default and it allows you to select.
