I got my Z1 compact on 31/01/14, and this problem started a few days ago. This morning I had to press the power button 25 times before the screen lit up. Have looked at the "troubleshooting" page for this issue and the only advice Sony seem to give is to make sure you have enough battery power.... this problem is occurring whether my battery is full or not, also I expect to be able to use an extremely basic function on my phone even when it's got a low battery.
I'm also having issues when picking up calls, I slide to answer and the screen freezes. Anyone else with this issue too? I'm going away for a few days and was hoping to use the phone as my camera. As soon as I get back I'm going in for a replacement.
Any real help with these problems would be really appreciated, to save me the hassle
I am also experiencing this issue after I updated the phone.
I have been offshore for a longer period off time and applied to new SW updates to the phone, and after that the phone is impossible to unlock..
Has anyone got any new information regarding this?
My new xperia z is also exhibiting issues with the power button not responding.
then it died completely.
all I had done since recieving the phone is to restore my data and apps (and installing previous xperia Z's SD card) and updating the software. - this is really annoying as the phone should be (and perform) identical. especially as it takes some time to restore and reconfigure phone set up (e.g. sync with google account etc.) -I had my previous xperia Z for 12 months until a hairline crack appeared on screen rendering touch screen non-responsive.
only recoverable once the battery went completely flat and I then charged; I can now at least start the phone byt the power button is still tempramental (nees multiple presses before turning on)
I can sometimes see a slight flicker / change of screen tone on the a press of the power button, so it is acknowledging the press just not turning on (so I deduce not a hardwrae issue).
just now tried (whilst on charge) to turn on - with no joy - only then turned on when I disconnected from charger - all pretty random. -I will try resetting the software via pc companion as a last ditched attempt - if it still has issues I think it will have to go back to sony
