Since the latest software uppdating, I cannot answer incoming calls. The phone is ringing but no botton for answering shows up. Thank you for help, urgent!
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
The problem is solved!
If the screen remains black when the phone rings go to Settings - Apps & swipe along to ALL then scroll down to InCallUI & enable.....:smileysmileywink:
@dandy63 wrote:If the screen remains black when the phone rings go to Settings - Apps & swipe along to ALL then scroll down to InCallUI & enable.....:smileysmileywink:
Hi, following your information I found that there is only the force stop bottom in my mobile.
Have you got any other idea of what could be causing the problem ??
Thanks in advace
Hi everyone.
Just a little update, I finally got to solve the problem with my Z2.
Go to Settings, Personalisation, Manage notifications and make sure that the "Phone" is ticked, you might be able to see the "InCallUI" there as well and it should also be ticked.
Hope it helps.
HELLO: I would like very much to share my experience of NO incoming phone ring volume . I have the problem solved finally. In the past few weeks, I got NO ring VOLUME but the Sound and Notification's RING volume was at its MAX level. I tapped on it, and got NO sound. ALl incoming call activated the vibration but NO RING TONE. Finally I found out EXACTLY which APPS caused this problem. It was the WECHAT VOICE call option. During WECHAT VOICE MODE, the righ tone is compressed and I got notification thru vibration and a display is open on the top of the phone for me to answer or decline. After finishing the WECHAT voice mode, WECHAT did not close this feature probably and the volune ring tone was still in the compressed mode. That was WHY the ring tone was SHUT OFF every time after my WECHAT session. To solve this problem is to POWER OFF and then POWER ON again everytime after the wechat voice session. This solved my problem. IF anyone is using the WECHAT Voice feature, and get NO incoming call ring tone, this may be your problem. thank You for listening.
I cant answer my phone normarly. When I receive a call there is phone sign at the top left of my phone.
