Problem recording video - little jumps
absolut33
Hi
When I record with my Xperia z5c sometimes I have little jumps in the recordings, the image pause one or two seconds and then continues recording.
Someone have these problem?
Thanks
9 REPLIES 9
CameronT
Hi @absolut33,
Have you tried resetting the Camera app? (Settings > Apps > All > Camera > Clear Data > Force Stop)
What quality are you recording in?
absolut33
Hi
I've resetted the camera, and I have the same problem. I record in full hd 30fps
CameronT
@absolut33
Do you have any other performance issues with your phone? Such as lag/slowdown, freezing etc?
Try running the software repair and advise how you get on.
SebastianD
Were are you storing the vídeo while recording? Internal storage or SD card?
I think I used to have some jumps when recording at 24fps (in an older firmware and camera at least).
I always record at 60fps and so far I think it's fine.
smiffie71
I have the same problem and that was straight out the box from Vodafone. Not only does it jump frames, the sound ends up out of sync.
smiffie71
I've also noticed it's slow to take photos and save them and has crashed the camera a few times. That's to sd card. The phone on the whole seems very slow. My z1 used to open applications quicker.
ddr2
I have the same problem on Z5 (not compact).Have a look at the video, itis recorded with sony z5 6.0 fhd@30 fps (the problem is only @30fps FHD).
https://drive.google.com/file/d/0B8VEuJgGJNygbGJ6QVRGTnNYYjg/view?usp=docslist_api
Pay attension at 00:29
RezaZahra2
hi.... go to setting... then location... ouch on camera...touch on permission...disable location ... finished... you solved!!!!!!!!!!!
absolut33
Thanks
Fortunately I sold the phone
No more sony
