This is the build: 32.3.A.0.376
But it is irrelevant because it is a problem that started to update to Android 6.0, the problem was not solved until today, I guess because the language of my country is Spanish and is a big problem contact with english support, I am using a translator to talk to you.
Returning to the subject, in my country is used city codes, the number is in really 3-123456, but to talk from all cell phones of the city should write an additional 3.
The reason? I do not know, but it is.
The call number should be dialed 33-123456, if I call from the phonebook, it works and uses the number stored 33-123456.
The problem is when I want to call from the number stored in Call History, the number is saved (in the history) as 3-123456, then when I call a computer voice of operator tells me that the number does not exist and the call is not made ....
What I ask is that the call history does not put or remove anything to the numbers I have called, that I save them as they were used when calling.
It passes in normal mode, safe mode, after a wipe, etc.
The problem is in History.
