Power button no longer working
akosiJD
So my Z3 Tablet Compact has seen better days. It has fallen countless times but has endured all of them. My only problem is that part of the upper part of the screen has detached from the casing. And I can lift it up a bit to see the under side of the screen. Recently, it got moisture inside from being placed inside a bag with wet clothing and the bag was under the sun. I saw the camera lenses fog up. When I tried pressing the power button... No response. And now the volume up button acts as volume up and the power button. I also noticed a small crack near the power button. I already placed the device under rice grains to absorb the moisture overnight. Still doesn't work. Any fix for this? Thanks.
Emil
Enthusiast
Hi @akosiJD,
I'm sorry to hear this.
I would recommend that you get in contact with your Local support team for assistance with having your device sent in to an authorized service center for repair. Your local support team can also assist you with any question you may have regarding service routines in your country/region.
Let me know how it works out.
2 REPLIES 2
Emil
Enthusiast
Hi @akosiJD,
akosiJD
Thanks for the reply. Managed to get the buttons to work. That was the good news. But the tablet went into bootloop so I had it checked in a Sony Service Center only to find out that I had to leave it for 2-3 days and the estimated cost would be incredible. So I went home and tried to revive the device myself. All warranties void now. Tablet is working now tho.
