I read about this before on this forum I believe and it was somebody in Sweden who experienced the same issue as you. I remember that he was referred to send it to the Sony repair center but I don't know if he went through with it and reported back with the results. I do not recommend gluing the ring back or anything like that. If you are still under warranty then Sony really should repair this for you.
Sorry to hear that, you have to contact your local Sony Xperia Care
You beat me to this thread Uliwooly. It's ironic too because I when I clicked post I figured you probably already read the thread and maybe even already posted.
Keep it away from water, I don't think it will be cover under warranty but that's my opinion
That's just my opinion, but to be certain you have to stop by your local Sony Xperia Center
Even i am facing the same problem. did they replace it as it is manufacturing defect???
