Hello, since a few days ago, I could not search for podcast channels, within the Sony music application on my Xperia Z3. Can somebody help me?
Hola, desde hace unos días, no pudo buscar canales de podcast, dentro de la aplicación música de sony en mi Xperia Z3. Alguien me puede ayudar?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
What happen when you:
Open the Music app > swipe left to right > podcast
Hi @Josmavi!
Unfortunately, the Podcast feature in the Music app was removed in August 2016, so I would recommend that you look for a third party podcast application in the Google Play store.
If you search for "podcast" there should be plenty of different applications to choose from.
I hope that helps!
Install this file and than it will add the podcast function you the music app (works great) :
https://www.apkmirror.com/apk/sony-mobile-communications/podcast/podcast-2-1-a-0-10-release/
