Pink spot with xperia z3 camera
babyripp
Hi, I just got my z3 less than a week ago, today I notice pink spot with the camera and all the photos I take. Is this a software issue or should I take it to sony a.s.a.p? Sample photo:
216 REPLIES 216
lodep
Same problem here !
Is it a joke ? The remote play feature not working because of conflict with bluetooth controller, now this pink problem on photos ? The two key features for me (photo and remote play) are not working ! ARE YOU KIDDING SONY ? More than 600 € for this ??? Please do your job and take care of us, WE NEED AN UPDATE (and more than one now...).
Jhines
I'm experiencing this issue too, hoping for a solution so I don't have to return my device.
Is there anything that differs from the Z2 sensor that would be causing this?
Logic tells me this would be a software issue since the same sensor is used in Z2, Z1, etc
Wordfool
Another pink-spot Z3c here... seems to definitely be a white balance issue because I can manually change the white balance and watch the spot appear or disappear.
Sony's response in this thread is rubbish, of course. The point of a phone camera is to take quick pictures and the idea of dithering about adjusting the white balance for every indoor photo is ludicrous. Forget Intelligent Auto... they should call the camera's auto mode "Unintelligent Auto". Like many others here, the supposedly good camera is a big reason I chose a Sony phone over a Moto or Nexus.
What are the chances of actually getting a patch to fix this before the Lollipop update next year? I suspect slim to none. Until the company actually steps forward and says "yes, this is a problem with our camera and we'll fix it" then I'm not even confident the Lollipop update will address it.
Has anyone tried third-party camera apps to see if they give better white balance control?
RickGM
Same pink spot issue here. Sony synonymous with great cameras. The boasts of the great camera on the Z3 were the biggest influence on me buying this device. It is clearly a massive issue and one would hope that Sony are taking this extremely seriously. The bad publicity that may result if they don't fix it promptly could be devastating for sales of the flagship Z3.
dannny
New
@Wordfool
I've tried Google Camera and VSCO Cam and the problem is still there for me.
Jhines
Sony, care to fill us in on this? DO we need to return our devices or will this be fixed in a software update?
kynesino
I have a feeling this issue looks like SW problem. Probably WB problem. Just from my very short experience it's mostly visible when AUTO WB is set, a lot of white/grey in background and artificial lighting condition. When I move the phone WB changes and center of the frame becomes more or less pink.
Sultan9
Rickard
This is a normal behaviour characteristic if there is lens colour shading in the camera lens.
Factors that affects this are colour temperature and lighting conditions and generally, it will be more noticable with a thinner camera lens.
When a picture is taken in these special conditions and the object is white with smooth surface, it may be observed that the edges of the picture appears darker and the centre is bright.
In these conditions ISO, light measuring and white balance adjustment may be affected resulting in the pink/greenish tint that occurs. This is normal.
Please try to adjust the lighting condition or try different camera mode such as Document mode or the workarounds detailed earlier to get the best picture possible for the subject and lighting condition.
hanime
Is anybody returning their Z3? I did.
