Hi there. I just bought a 64gb sd card and used it. I connected the phone to PC via USB and it didn't recognized it,and so i just restarted the phone. Untill now i had no problems with restarting the phone but today din't want to start and the green front light is opened non-stop. What should i do? I tried to shut down,i tried to repair and nothing. I need help please.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
So now the device doesn't power on?
Yes,and the green light is still on.
Ohh gosh,thanks man. I just had to power button and Volume up. You the best.
Nice,I thought you already tried that,that is why I said to repair.
I tried just holding the volume down. Heart attack,ty man.
One more thing, i'm kinda afraid to use again the new card. What do you say?
Do you have a microSD adapter? Reformat the card in your computer and check again.
Yup,ty bro. Have a nice day.
