If you can not solve this problem. You have to restart your phone to make your ringtones work or you can try the way by go to Developer mode -> Background process limit -> change to No background process limit. And try it again. Some people have shared this way to fix their problem.
I purchased a xperia xa dual one week ago. but there is a problem that I need to restart the phone every time to get it to ring. I have factory reset but there is no improvement. It rings for a couple of calls and then goes back to silent mode. very unpleasant experience. Do you have any solution for that OR CAN YOU SUGGEST ME WHAT TO DO NEXT
@anay_messi wrote:I purchased a xperia xa dual one week ago. but there is a problem that I need to restart the phone every time to get it to ring. I have factory reset but there is no improvement. It rings for a couple of calls and then goes back to silent mode. very unpleasant experience. Do you have any solution for that OR CAN YOU SUGGEST ME WHAT TO DO NEXT
Could you repair it via Sony PC Companion and check again ?
Hi guys,
I have check a lot of way to fix this issue. And i figured out 1 way more: Charge your sony phone and try to use another phone call to your phone when you are charging it, when it happen, you phone will back to vibrate mode and you have to wait for about 3 secs, you will hear your phone ringtones with small sound. make some times like that, your phone will have ringtones but in some fell seconds after have a phone call. You can use Flash for incoming call app to use your phone in this difficult time. I hope that sony team will fix this issue in the near furture.
