When I use the Quick Charge(UCH10) my phone gets overheated while charging and down to 30 percent it is getting that slow that you can not use it anymore. Additionally, it crashes down at least once per day.
Another issue is that the battery is after 4-5 hours empty after recharging it by quick Charge.
When I use the UCH20 I don't have these issues.
Since i use the Quick Charge as well, i can tell that, in fact, the phone does heat a little bit.
However, it seams that the problem could be on the battery...
Try to ckeck the battery health:
*#*#7378423#*#*-service tests-battery health test
Actually the battery is totally fine.
I think I just don't use the Quick Charge any more. But thanks for the advice
One time, my device did not charge with the QC2.0. I had to fully charge first with the "normal" charger, and then the QC2.0. worked.
