No sound when loudspeaker activated during call with 5.1.1 23.4.A.0.546 R6C
Z3jjj
I just received my z3c from repair (camera issue). Since then, when I activate loudspeaker during call there is no sound at all. The diagnostic test on the z3c is working properly.  I suppose this sw related so but is this issue known by others?
Z3jjj
Problem solved after firmware upgrade.
9 REPLIES 9
Sam
Legend
Legend
@Z3jjj - I would try booting in Safe Mode to see if the issue continues:
To enable Safe mode
  • While the phone is on, press and hold down the power key.
  • In the pop up window, touch and hold Power off until the Reboot to safe mode message appears.
  • Tap OK to reboot in safe mode.
Z3jjj
I tried it but without success. Same issue.
Sam
Legend
Legend
In this case I would advise trying a firmware repair:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
Z3jjj
Hello, i did it...twice but still not working.
Thx for the advice.
Sam
Legend
Legend
In this case it would be best to have a chat with your local Xperia Care team as the handset may require assessment.
Z3jjj
Ok thx!
Z3jjj
I have tried the headset and it did not working properly.
Thus, my z3c nées to go back to repair...:-(
Thx for the support. As soon as i have it back i will post their analysis.
Z3jjj
Z3jjj
Case closed
