no antena after lcd replace
nanobano
hello .my z2 lcd cracked i change my only lcd (no frame ) when i test its have signal
after instal i feel its have no weak signal in home i tested antena cable with multimetere its seems works corectly i cheeked connections they seems correct
what percentage problem may be from antenna module ?
or other
please help me
thanx
3 REPLIES 3
@nanobano
Did you replaced the screen or did you get it done somewhere else or by Sony?
nanobano
i replaced its lcd .(only lcd) its frame is its original .
after replace for a short period charging drain was fast
now charging drain is normal and  signal is poor iner of bulding
may be signal antena mudule be spoiled ?
@nanobano
That's a possibility, check the antenna
