Hi.
The NFC on my Xperia Z1 suddenly does not work anymore..
Yesterday, I connected my Z1 to a Smart Tag and the phone recognized it through the Smart Connect App. So the NFC was still doing fine. Then a while ago, I tried to connect my phone with the SRS-BTX300 NFC speaker, but it doesnt seem to connect and the phone does not respond to it. I then tapped my Z1 on a Smart Tag which also doesnt work anymore.. I already did a Phone Repair using SUS and did a factory reset, but it doesnt seem to help..
The phone is just 3 days old! Does anyone have a solution to this? Please help!
Sounds strange! Have you tried to turn off and on NFC under settings > more > NFC?
Also make sure that you have the screen turned on and unlocked when you are using the NFC function in your phone.
Yes. I've already turned it off, then on again, even restarting the phone doesn't help. It worked perfectly yesterday but since this morning it doesn't connect to any NFC enabled devides anymore..
When you say 'NFC enabled devices' do you mean devices paired to your Z1 using NFC? It might be that NFC is working but your Bluetooth is swtiched off.
With that I meant paired devices. The speakers, for example, the SRS-BTX300, whenever i tap my Z1 on the speaker's NFC spot, it automatically turns the bluetooth on and pairs the phone with the speakers. (I have Smart Connect installed on my phone) It works with my Xperia S, but not with the Z1, which worked before..
Mine too. Its just suddenly not working.... Any one have any ideas on how to fix this? The phone is only 3 weeks old.
Pls help.....
I can confirm that NFC isn't working on my Z1 either.
This has been confrimed by using the Service Test menu via *#*#7378423#*#*>NFC>NFC Diag Test
I have tried reading numerous tags, try numerous devices and I get nothing.
SWP…No NFC SIM Detected is normal apparently and shouldn't be worried about.
I'd like to see this fixed as so far I've purchased a premium device with NFC faulty and ANT+ support lacking... (not entirely Sony's fault, but still...)
Have you tried running a software repair since having this problem?
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
Ok I will try it today and will report is as soon as i got result from it ... Thanks
