Hello. I'm having trouble that my z3c won't charge at all by using micro usb. But it can be charge by magnetic charger. How to solve this problem. It's happening suddenly or right after i washed it under water but it still works well only problem with charging by micro usb.
It's not wire problem because using the same micro usb can charge my other xperia tablets. Can it be that the micro usb is broken?
If the phone had any physical damage water could've leaked in, contact your Local support and request a vacuum test.
