i did register my phone with locate my xperia service and then lost my phone during december since now i havent got the phone and i keep on trying to find it, so i find it difficult for me to say this program works while it didnt for me.
Topic edited by Rickard
For MyXperia to work
https://myxperia.sonymobile.com/
If you happen to misplace your Xperia™ device, the my Xperia service helps you to find it and protect private information by locking your device or even deleting all information on your device. The my Xperia service is offered by Sony Mobile Communications free of charge.
The my Xperia service uses the Google account on your device. If you are using several Google accounts on your device, you can sign in with any of them. You can connect several devices to my Xperia, using the same Google account.
For the my Xperia service to work, your smartphone or tablet must be turned on and has to have a working data connection.
LocateThe Locate function helps you to find your Xperia™ device, by locating it on a map. If my Xperia cannot find your device immediately, an email is sent to your Google account once your device has been located.
Sound alertIf you misplace your device, for example, when you are at home, you can make it play a sound to help you find it. The sound alert overrides all volume settings on your device and plays the sound on full volume.
LockYou can lock your device with a four digit PIN code. The PIN code that you choose replaces the existing screen lock (e.g. pattern, PIN, password) on your device.
When you lock the device you can also write a message that will be displayed on the screen of your device when it is found. You can also set a phone number where the finder can reach you.
When you lock your device using my Xperia, a confirmation message is sent to your Google account.
EraseIf you want to make sure that nobody gets hold of any private information on your misplaced device, you can erase the data remotely. You can choose to erase the data on internal memory, memory card or both. Once the data has been erased, it can only be restored if you have a backup.
When you erase your device using my Xperia, a confirmation message is sent to your Google account.
From a computer or another device, verify that your my Xperia account is working by using the Locate, Alert sound or Lock function. If nothing happens, find and tap Settings > Xperia > My Xperia > Enable necessary services on your device. Then verify that my Xperia is working.
i didn't lost my xperia zl. however, i wanted to try myxperia to see whether it's working or not. myxperia can locate my phone, but when i try to lock the phone, or do the sound alert, nothing happen. what should i do to make these work?
my xperia Z was. Stolen last night while im dead asleep. Can not use my smart watch because it was disconnected. I tried to locate it with my xperia.. It says cannot locate my phone, in fact ibwas able to do it when i activated my phoneand sent me an email saying phone was found... Now when it was real lost, can not locate it.. I have also read that offline access, meaning kt can locate phone when it is turned off.. Why it cant locate it? Pain in the **bleep**... Can anyone help me to find it?
i have same problem.. can't locate my stolen phone last night..i am hoping for immediate solution..
Hello Sony,
After I press the erase button can I still locate my phone? Now I cannot chose the locate or lock my sony phone from myxperia website.
