I have XperiaZ5 from 3Network, been using it for over two years now. Recently it gets very hot even on call. I have restarted and reset the phone problem persists. Any idea what might be the cause?
The more you use the phone the hotter it'll get, also, since the phone it's more than 2 years older the battery won't hold charge as much as it used to
Please can my phone battery be changed and how much will it cost.
Back-up your data ASAP! This is a design flaw. Replacing the battery will not fix it.
The phone structure is too flexible (terrible engineering) and eventually the motherboard/cpu inside breaks and goes into a partial short-circuit.
