Music stops... With every player!
defx26
Hello all,
I am facing problems with ALL music players on my Xperia Z3 Compact. The music stops to play afetr some minutes, again and again. Sometimes it plays 3 minutes, sometimes 10 or 20 or 30 and it stops.
It doesn't matter which player i am using (Spotify, Walkman, TuneIn Radio), and/or the music is a stream or a locally saved MP3 File. It continues to stop always!
First of all i thought it was a dirty Headphone jack, that "simulates" a plug-out of the jack connector - but i am facing the same issue if i am connected to speakers or my car sound system by bluetooth (even in Chromecast mode!).
I waited for Lollipop 5, since i had this already under Lollipop 4 - but the update brought no change!!
Does anybody has an idea where i should start troubleshooting, or better who can give me a solution? Does anybody out there has/d the same problem?
Thanks!
Manuel
13 REPLIES 13
Nigelfarage
I uninstalled avast but didn't solve the problem. I listen to radio by my phone while driving and paused can cause an accident.
Ricardo1983
Did anyone find a solution to this problem?
I find all media is interrupted when playing. Sony Xperia Z5.
MichaelWalter
Found the problem. This behavior is due to corrupt app data. To repair:
Delete from all apps the data (under settings apps->memory->delete data), each app one by one.
Another way is a factory reset, but make sure you don't load the backuped app data, can be disabled under backup and restore(or the problem happens again, happend to me 😞).
Greasy
Uninstalling Z Camera fixed it for me.
