Translation via Google Translate:
Hello.
Last July my sony xperia Z5 which was supposed to be waterproof, was put a few seconds without the pool.
After that he started to disfunction and did not turn on again. So I decided to put in a few days in rice. And finally I left it until 2 weeks ago. I am writing to you now with him. it works almost in the direction where I have the mode without fail that is activated. I can not deactivate it even In the restaurant In parameter of uzine.
Do you have any advice to give me ??
thank you in advance
Bonjour.
En juillet dernier mon sony xperia Z5 qui etait censé etre étanche, a été mis quelques seconde sans la piscine.
Suite a cela il a commencé a disfonctionner et ne se rallumait plus. J'ai donc decidé denle mettre pendant quelques jours dans du riz. Et finalement je l'y ai laissé jusqu'a il y a 2 semaines. Je vous ecris actuellement avec lui. il refonctionne a peu pres dans le sens ou J'ai le mode sans echec qui est activé. Je n'arrive pas a le desactiver même En le restaurant En parametre d'uzine.
Auriez vous des conseils a m'apporter ??
Merci d'avance
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Unfortunately, the translation is not accurate and I didn't get what happened after you managed to get the moisture out with rice. Can you elaborate more, please?
