Hi everyone,
I have Z1 for one year, and it was really nice time, recently i upgrade to Lolipop 5.0.2, but then the mic stop working good.
If i make or recieve a normal call, the other side can not hear me well, the vocie is bad and sometime its gone totally.
But if i try to recode a voice or movie or even make an internet call using Watts App or Facebook massenger, the mic is okay and fine.
Only in regular call it stop working good.
Any help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Great to hear that
Boot on safe mode and see if you experience the same thing.
How to boot on safe mode.
Also, you can try to reinstall Lollipop with Sony PC Companion
Sony PC Companion.
Thanks for replying, but before reinstalling Lolipop again, I woundered if the PC companion can backup everything in my mobile including all What's App chatting, massaging, and all samll things, i want my mobile to return exactly the same, after restoring the files, if not, i would be a very hard time for me
if you did it before, can you please share your experiance?
Hi Sony_Z1, welcome to the community!
Exactly what contents will be backed up may differ depending on phone model. You can view detailed information about this as you follow the steps in the Backup & Restore wizard. PC Companion does not back up apps/games, to restore them back on the phone just log into Play Store with the same acount you used to previously download your apps > tap the three lines in the top left hand corner > tap My apps > from there you should be able to tap Install on the apps you wish to have back on your handset.
Here are some Alternatives
It'll be wise to create a backup of Whatsapp and move it to the SD card.
