Loss of message notification light after upgrade
Hallett505
This morning (22 September 2016) I accepted the updrade to version 23.5 A1. 291  and since then I have noticed that my message notification light no longer works. So far I have disabled stamina mode and performed a restart but the issue still persists. Any suggestions for a fix would be most welcome.
Hallett505
Thanks, after restarting it a couple of times and running in safe mode and then back to normal, it now works!!  All good!
10 REPLIES 10
Does the notification LED work at all?
Hallett505
Well it was yesterday, before the upgrade
CameronT
Hi @Hallett505,
Welcome to the community.
That's very peculiar. Thinking_Face As uliwooly asked, do you see the notification light at all? For example, when you plug in your phone to charge, is there the charging light?
Can you please also test your phone in safe mode and see if the same issue occurs?
Maybe the issue is not the update but it will be wise to repair the phone with XC
Xperia Companion (XC)
Software Repair Guide
Hallett505
Yes, I just plugged in to recharge (the battery has lost 40% in 4 hours by the way, which is way more than usual) and yes the nofication light is on (dark orange) showing that recharging is occuring
CameronT
@Hallett505,
Does this happen with all app notifications? Or just messaging for example?
Hallett505
I started in safe mode and sent a text and teh notification light flashed a few times but then stopped
CameronT
@Hallett505,
Try going to Settings > Apps > Messaging > Force Stop > Storage > Clear Data, then restart your phone and test it again.
If it is still doing it, do the software repair uliwooly suggested as it is likely to resolve this issue.
Hallett505
