Firstly, I am wondering if there is any way to limit data usage based daily instead of monthly.
Secondly, whenever I am calling it goes well but when I end the call or my friend ends the call, the top speaker gives a sound as well as the bottom one
Hi @Kycpokemon, welcome to our forum!
Are you referring to the setting called "Data limit" in Settings > Data usage? If you are, this can only be limited monthly. I can see how it could be useful to have it daily as well so I will make sure to forward this internally as user feedback.
Regarding the sound being played in both speakers when you end a call, try rebooting your phone in safe mode and see if you experience the same behavior when third party applications aren't loaded.
Let me know how it went!
@Jonas wrote:Hi @Kycpokemon, welcome to our forum!
Yes I am refering to that setting, it is very useful as I have 3Gb and if I can split it evenly with 100Mb a day, it will make life so much easier then to manually check.
And regarding the sound, in Safe Mode it was gone but when I rebooted it back into normal it is also gone. I will continue to moniter it after a day and report back.
Hi again @Kycpokemon,
I'm glad to hear that you don't experience the sound being played in both speakers now and I will make sure to forward your suggestion internally!
Let me know if you experience this behaviour again and have a great day!
@Kycpokemon wrote:Firstly, I am wondering if there is any way to limit data usage based daily instead of monthly.
I'm totally pro at restricting data.
Restrict each app for background data. Then turn off 4G, then turn off Mobile Data.
Datasaver is there too.
You can also set the mobile data to change usage cycle each day
"You can also set the mobile data to change usage cycle each day" What do you mean?
