Impossible to make or receive calls and screen goes back
Irenepanik
I have  read several having the problem with screen going black during a call, but my problem is different in that it does not even work to make the call. Phone works fine using all apps, sending SMS etc, but once I try to place a call, the screen goes black and I do not hear any signals going through or nothing. At the other end the call takes place, but with noone on the line. Same for incoming calls, looks ok until I press answer button, then the screen goes black and I can not hear or be heard. Once the call is ended from the other side, which can take long in case of answering machines etc, the phone looks ok again. I have taken off the screen cover and cleaned the phone and I have reset the phone completely, but problem remains. Anyone has a clue what the problem is!?
12 REPLIES 12
NeoBeum
Enthusiast
@Irenepanik wrote:
can you go to
Settings » Accessibility
and see if "Power button ends call" is disabled, near the bottom of the menu
If it isn't, disable it, and next time you use Call, receiving or send, and the display turns off, press the power button. See if the display comes back on
I've had a bug recently where I could only answer the call by using the answer button on the notification shade, because I had the dialer open in the background, while I was typing messages in another App, and I locked the phone at the same time a voice call came in, and the normal calling screen to answer got hidden
vikri
I guess u use 4G signal right.? Try to change to 3G..4G cant use for call right now..please click solve problem if my answer is helpfull
Irenepanik
It was disabled...
NeoBeum
Enthusiast
@Irenepanik wrote:
It was disabled...
does pressing power turn the display on?
Irenepanik
Sorry, did not do it.
Irenepanik
Sorry, all settings right...
NeoBeum
Enthusiast
Do you have backups of everything?
There's something wrong, because that setting should always turn the display on when you are in a call.
The next option would be factory reset to see if the problem is fixed during a software reset
In Lollipop the camera acted as as secondary  CCD/Proximity sensor, so that both Proximity and Front Camera bits must get flagged for the display to recognized that you have the phone to your ear.
I might flag this this to escalate, as I'm curious to see if Sony can make changes to add something like this back to override Google's global defaults
Fallauk
I have exactly the same issue.
I am using an E6653 - Android version 7.1.1
Security patch 1 Sept 2017
Build - 32.4.A.1.54
When making or receiving calls the screen goes Black and I am unable to use any of the in call functions like the key pad etc - to hang up a call I had the enable the power button to hang up function as the screen never returned.
Is there a fix due soon ?
Jmmrt9
Hi ive tryed all of the above things my screen still goes black when i push answer for the call so i cant use any of the keyboard as in press hash or press 3 whatever this is a contract phone but its learned me a lesson always insure your phone and have a cheap back up for when you have to send it back for repairs but to save all the hassle ive bot a gorrila glass screen protectot and an armour case and hopefully save putting my phone in for repairs for a broken screen so let this be a lesson to ye all a broken screen£100 a screen protector 5to 10 quide you do the math plus 4 screens the guy that fixes phones put on my z5 ither it was cheep knock off screens then the last one seems to be working im putting it down to him buying a better quality screen but anyway my fone still goes black when i answer a call if its a software glitch i dont know but i do know i wont buy a experia again
