Since you have a dual phone, have you tried with both of your IMEI-numbers? Otherwise, could you send a PM to me with your IMEI-numbers and I can check from here?
For IMEI number issues you would be best contacting Xperia care http://www.sonymobile.com/global-en/support/contact-us/
thank you
Please also make sure you are entering only the 15 digit number starting with 35 (usually) with no dashes or spaces.
i tried all of that but it is not working, IMEI is not valid
the xperia support team untell now there is no response.
IMEI: [removed by Hampus]. is not valid. why? i buy this phone a week ago. i can't update.
i tried many times also with dashes, but still not valid my IMEI. what is the prblem?
Hi fusionist,
Information such as IMEI, should not be posted here at the forum. Please check the discussions guidelines (in my signature).
I have added your phone manually from my side and it looks OK. Could you logout and login again to see if you can see your phone now? Otherwise, send me a personal message with the email address that you use via sonymobile.com.
Hi Hampus, I've been trying to register my device and says the same thing IMEI no valid, I've bought this phone like 3 days ago
Xperia M4 Aqua
