Hello everyone. I want to know how to activate battery saver?
Thanks in advance.
There are several types of battery savers. If you go to settings - power management, there is stamina, ultra stamina, low battery mode, which are from Sony as far as I know. And if you go to battery usage and tap on 3 dots, there is the inbuilt battery saver from google.
Thank you so much alexdon . you were a great help.
Another thing, is using battery saver with Stamina mode good or bad? I mean activating both battery saver and stamina mode .
Thanks in advance.
Well, I do not use both of them at the same time. I only have stamina set to kick in at 30-35%, so I can enjoy the smartphone.
how to activate battery saver when it not able to be activated
