Again that's normal, its all about how you use your phone, if you sync multiple accounts it will drain your battery faster, keep in mind that the longer that you have the screen on the faster your battery will drain, also you have to keep in mind that if you have poor network coverage it will drain even faster
Like you can see on this other thread
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/Xperia-ZR-Help/m-p/478419#M25050
That's normal, your phone is heating up because you are syncing multiple accounts and that will drain your battery, again that's normal
That's normal, the more you use the phone, the hotter it'll get
It will heat up your phone but it take a bit longer, you will be lowering the CPU clock speeds, I wouldn't go to that extent for minimal differences
