I tried many things...including cleaning the jack,clearing the data of SMART CONNECT but the problem resists..
the keeps disconnecting the headsets....
is it a software issue or what......in my country,theres no as such authorized sony customer care for XPERIA.
what shuold i do to solve the problem.
plzzz help
Hi, the day or previous day that this happened with your headphones...had you downloaded/installed any new apps or had you just downloaded any software updates :smileysmileywink:
YES i had installed POWERAMP music player.....
i yeterday uninstalled it nd even deleted its data from the phone.
the phone now recognizes headphones but keeps disconnecting
Consider performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
I face it many times when I remove headphones while the music is being played and try to plug it in again. Just reboot your device when this happens. Haven't found anything new.
