I have this strange problem with my Z1c's GPS. It works with Google maps but doesn't work independently. Like, when I carry out tests using the built-in diagnositc tool and the Service menu(*#*#77378423#*#*), the tests fail. The Service menu GPS test just keeps searching and never completes it. I tried it outdoors as well. Whereas, as soon as I switch go Google Maps, the location is pinpointed instantly. Would appreciate any help regarding the issue. I'm on Lollipop 5.0.2, firmware: 14.5.A.0.270. Thanks! .
Thanks again, @komilAD!
Anytime :smileysmileythumbsup:
"Btw, how come Google maps is able to pinpoint the location if the GPS isn't working? I didn't get that part"
Because in "high precision" mode it can more or less pinpoint you by using known coordinates of the WiFi connection.
I have the very same issue under Android 5.0.2 on Xperia Z (c6603). So far I've gathered that this problem started after 4.4 or 4.4.4 Android update and has something to do with Google Play services, it's been over a year since people are complaining, but neither Sony or Google has solution to this problem. So now I'm planning to downgrade OS to 4.3 using 3rd party software and see if that works.
P.S. What's really annoying, the phone does see satellites (curently it's 22, I believe I haven't seen it registering less than 16), but it still isn't able to calculate coordinates, so it seems that GPS module works and this is purely a software issue.
Couldn't log in for some reason, had to change my alias.
So, I still haven't downgraded my OS on my phone to earlier Android, since I've discovered GPS actually works, it just doesn't work all that well. Whenever I'm at home, at work (I'm sitting at a very large window - from floor to ceiling, so GPS should work, but doesn't), GPS test does see satellites, but can't calculate coordinates.
Another example - this weekend I was at an open air festival, out of several dozens of photos only five had geotag added.
So, GPS does work. Sort of. Bought a cradle to fix my XPERIA Z1 on my cars windscreen, navigation does work, not very precisely, but for most part it does.
Therefore I recommend to do a GPS test at a park or beach where a lot of open sky is available.
Meanwhile another much, MUCH more upsetting problem surfaced - this phone sometimes fail to function as a phone - it doesn't ring or vibrate for incoming calls, only shows a message on screen. Searched online, I'm not the only one who had experienced this. Resetting factory values helps for some time, but then again alerts are gone. So far I've done reset twice in two weeks. Contacts are saved on Google, so as soon as phone is back online, they are back, but the software need to be downloaded repeatedly, good thing phone remembers the list and does it by itself... mostly.
Bringing this up again, because the problem is not solved for me. I have the same issue of the test not finding location, BUT I don't have the pinpoint accuracy in MAPS like the OP. Problem exists on a new 5503 with unlocked bootloader and Emma used to load the only "Service" that was available. GPS worked on the firmware that came on the phone when new, but as it was a UK and or Austrian software package, and I am in the USA on ATT, I wanted software better matched to ATT. (The Hutchison software package did not allow all the Sony LTE options, and there were "3" apps that I could not uninstall.) So.....
Since the bootloader is unlocked, I cannot use the Companion software to attempt repairs. Options? Even if I could relock the bootloader, I cannot figure out a way to get Companion to install a clean US (Android 4.x - 5.1) ROM on this phone. It seems to look into the phone's current settings and load what IT thinks is best for me. I would like to make my own choices please. 🙂
BACKGROUND: The phone came new with 4.4.4 installed with SEEMED to allow me to delete the ?five? Hutchison ("3") apps, which I did before I used Companion to upgrade to 5.1. Once 5.1 was installed, I noticed that the Hutchison apps were back on the phone AND this time I had no option to uninstall those five apps. i.e. They looked like system apps that I could only disable. As a result I went through the official bootloader unlocking procedure and used Emma to install the new "Service" on my phone. BTW, anyone care to explain the difference between "Services" in Emma and ROMs or Android OSs?
Thanks in advance for answers to either or both of my questions!
