FORGOT SCREENLOCK PIN
karlok
Hello... I'm using SONY XPERIA Z1
What can I do if I forgot my screenlock PIN?
Do I need to reset the phone?
IF reset is needed, how can I reset my Z1 at home?
45 REPLIES 45
gwhispererz
Hi, are you prompted with option to enter your Gmail account username and password after numerous attempts?
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
karlok
No.. I'm asked to type in my PIN password again and again ><
Tags (1)
gwhispererz
You need to reset phone with PC Companion or Update Service. This process will erase everything from your phone.
karlok
When I use the PC Companion, the phone cant connect to it. PC COmpanion has asked me to unlock the PIN but I had already forgotten it.
What should I do next?
gwhispererz
Update Service will work. Slightly_smiling_Face
karlok
Ok.. I will try it! Slightly_smiling_Face
gwhispererz
Don't forget your pin again or don't even set one. Slightly_smiling_Face
karlok
gwhispererz
Hi Karlok, just replied your other post. Slightly_smiling_Face
