Fast charging
havirfan
Fast charging
My device is z5 dual e6633 and I bought few days ago
Fast charging function is not working
9 REPLIES 9
980ctane
Member
Please see my posts on this thread here. I tested this extensively over 6 weeks after I purchased the Z5 Dual and a UCH10 Quick charger and found it wasn't charging any faster than the stock charger.
I proved that it does work by installing the single sim firmware to the phone but this wasn't a viable solution as the sim card was no longer detected.
Sony have falsely advertised the Z5 Dual as Quick Charge is not enabled in the firmware of this model even though the hardware has the capability.
I tried to report it to Xperia Support but they just don't seem to care as even though I ended up speaking to the escalations team, they have yet to get back to me.
pravi
Latest firmware xxxxxx.154 (7.1) with sept security patch broke this function with stock charger as well as with others too.
NeoBeum
Enthusiast
Are there any differences if the device is charged while power is off?
980ctane
Member
Update may have broken this function on single sim Z5's but I tested the Z5 dual all the way back to Android 5.1.1 and it has never been enabled on this device.
NeoBeum
Enthusiast
My compact is fine,  but I'm using the AOSP boot because I have a custom recovery.
So I've made sure that all the Qualcom stuff is not missing
980ctane
Member
I eventually found that just flashing the kernel.sin file using Flashtool from the single sim firmware enabled the Quick Charge on the dual (keeping all the other firmware files from the dual firmware) but then the SD card could not be detected. I presume the single sim kernel.sin is looking for the SD card in a specific place and maybe it is different on the dual?
I have no idea how to do it but I presume if you could extract the kernel.sin contents, could you modify the section where the Quick Charge or max usb current is set?
I'm a web developer but not too familiar with Android development. From all the testing flashing one file at a time, I think the system.sin handles sim card detection (as this broke when i flashed the full single sim firmware to the dual) but kernel.sin seems to handle the Quick Charge and SD card detection.
NeoBeum
Enthusiast
you just need to rebuild the AOSP Device tree healthd module and the other qualcom bits to do with battery and charging... basically the boot image... which is the kernel.sin
this also has all of the USB detect and charge mode, and has the potential to disable charging completely if not done correctly
sometimes the sd card is mounted differentlyfor each build, or other parts of the firmware require different mount points
pravi
Im on stock and  not rooted !I always charge the device in offline mode > Shut it down then charge ! It takes nearly 120 mins from 15-90% with the lastest xxxxx.154 build which was 65-70 mins in previous builds !! Hope this could get a fix for that along  with latest security patch !
NeoBeum
Enthusiast
I suspect that it could be changes to SELPolicy that don't get applied properly during an update, or other policy bits and pieces causing problems further down the line.
I was messing around and getting my device to overheat amongst other things..
Screenshot_20171122-054258.pngScreenshot_20171122-054738.pngScreenshot_20171122-064610.pngScreenshot_20171122-060317.pngScreenshot_20171122-055516.pngScreenshot_20171122-054253.png
