Yes,it will charge slower.I have a magnetic cable and it charges slower than direct output through adapter.
It is charging at a slower rate,probably before you were charging at wall socket via the USB cable and adapter.
Anytime.
I brought a local magnetic cable ( USB to magnetic cable only) for sony xperia and this are my observations.
1. If connected in reverse, phone freezes or switches off
2. Charges more slowly compared to USB charging.
3. Over a period of time it started slowing down further and I thought the reason could be oxidation of contact and hence I cleaned both the phone's contact point and the charger contact point using rough cloth. Now charging is faster ( 1% takes between 5-6 minutes).
The culprit could be the oxidation of contacts
