Hi. I've noticed that there's no possibility to set "do not disturb mode" to end automatically on next alarm. This feature was available in 5.1.1, why did you remove it?
Now the option is back again and working. Nothing updated on my phone since I last tested and the option wasnt there. Very strange behaviour. My version 32.2.A.0.253
same here, working again, tought it because i was reinstalled the calnader
only did it today hope it wont happen again
When do you finally plan to fix it? Look like "until next alarm" is available only for first half of each month but it doesn't work at all. Have set "call only from starred contacts" but phone rings also with every other contact. Also there are sms and notification sounds which are turned off but ring too... So please do your job finally. This is long-lasting issue so far with no solution...
Not working again. What is going on?????
And now 1st of Sept it started to work again. Is it a joke or what? How DND feature could connected to calendar? Why I can use the feature in first part of the month but not on second half?
I received information today that this will be fixed in a future software update.
Still not fixed. How can it be so hard. I would imagine it's quite hard to get the software bug activated at the end of every month. It seems to be more easier to get the phone behaving similarly whole month... Some bug-creator had a hard work to make that happen.
So at the end of month you can't get the option to turn "do not disturb" feature on "until next alarm/wakeup". It is perfectly working in first half of every month...
@spacesnow This will be fixed in an upcoming software update but I'm afraid I don't know when it is planned for release. I'm sorry for any inconvenience this causes.
I've got an automatic rule set up on my Z5C to put it into Priority only each night at 10PM until 7am the next day. The rule works as expected when activating & does put it into Priority only, but when it deactivates, rather then reverting to normal, it sets it to Alarms only.
This has been the case ever since upgrading to 6.x and worked perfectly before the first upgrade. I thought it may have been a bug, so dealt with it until the next upgrade. Now on build 32.2.A.5.11 and still having the problem.
Can't think of any installed app that might be interfering. I use AutomateIt, but not running any rules to play with volume or any that trigger at 7AM.
Any ideas, other than setting an AutomateIt rule to turn set the ringer mode at 7:01??
