Disappointed.
Haffiman
Disappointed.
For unknown reasons, it looks like posts well within the forum rules, however not too positive about a product (Z3 Compact) that fails for second time 2 weeks after last repair, gets deleted. Moderator should at least have the decency of sending a PM with info and reason for deleting. I guess this post gets deleted as well, however at least the moderator in hiding gets the message!!
3 REPLIES 3
Thommo
Genius
There's this tool you have called Profile which shows you where your posts are and if you check you'll see it hasn't been deleted and was merely moved to your other post to prevent what the forum rules state as spamming - maybe you won't read this but if you do then you'll get the message
/t5/Xperia-Z3-Compact/Xperiaa-Z3-Compact-reboots-when-receiving-call/m-p/1045029#M16527
Haffiman
As the other post was cleared as 'solved', perhaps to early, it is more or less unavailable. Technically this is a new issue, however with the same phone and as such not spamming!!
If you noted, I even put a link to the old post for reference!!
This issue just make my perception of SONY phones drop even further, if possible, at the moment.
Spamming is something completely different, and accusing me of that is plain rude!!
Thommo
Genius
Topic closed
