if you still have warranty maybe you can have a repalcement at your local service center Local support
if you are practical like me, i used to have this problem I used to place a rubber band to connect the charger and device or I just slightly bend the metal part of the cord (do not try if you have the chance to replace the charger)
only your Local support can answer those questions.
most other usb cables ( or chragers from other oems) can charge your phone though not as efficiently as the one supplied.
