hi..
My xperia z2 camera isn't working. When i open the camera, only show the black screen with camera key and settings and take pictures but it is just black
The front camera is working well.
Try settings-apps-all-camera,force stop and clear data. Restart.
If the above does not help,you may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
I've cleared camera data but It still does not work
it did not work on safe mod
i repair with this program and camera didn't work still
In this case,stop by a sony service:
/t5/FAQ/How-to-get-your-Sony-Xperia-product-repaired/m-p/991374#M21
Hi @Mcjoanm,
Try the earlier suggestions in this topic and see if those help. If not then try performing a software repair using PC Companion with the help of a PC.
