Camera photos problem // screen rotate
GaryDarby84
ok, so, when im taking a photo with both front and back cameras, after the photo is taken and i view it, its always the wrong way around.
like, if i take a selfie, or a photo with camera held vertical, the saved photo is always horizontal.
how cant find anywhere in settings to change this. I love the stock camera with my z3c but because of this ive stopped using it, i know use camera360, and when i take photos with this, there is no problem at all, its just with the stock camera.
anyone know how to fix this, because id like to continue using the stock camera, if not ill be very disappointed and will continue using camera360.
my 2nd problem is, the screen does'nt auto rotate, even though i have it set to auto rotate, and smart rotate on in settings.
would love if someone could help me fix these 2 problems, i absolutely love the z3c but these 2 problems are extremely disappointing.
thanks in advance for any help, Gary.
15 REPLIES 15
Settings > apps > all > camera > clear data > restart your phone > check again
Also settings > display > screen rotation > smart rotation > off > restart your phone and check again.
GaryDarby84
tried both your answers, the camera is still the same, same with rotation Slightly_frowning_Face
After trying my suggestions, restart the phone and take new pictures, take one on landscape and another on portrait mode, see if you experience the same issue with the NEW pictures.
BTW do you have a protective case, perhaps a magnetic case?
GaryDarby84
i did try take a picture after using your suggestions
i take a pic with camera vertical, and it saves the pic horizontally
and visa versa i take a pic horizontally and it saves vertically
and yes, i have one of those like book/wallet type case, with the magnetic thing to hold the cover closed
i even removed the case and followed yours steps, restarted and tried again, and its exactly the same Slightly_frowning_Face
GaryDarby84
ive backed up my photos, so ill try a factory reset, and try the camera then
Repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
GaryDarby84
how do i repair it with pcc, i cant find the option
You should be able to see it, repair the phone its the same as re-installing the current update.
