It is not anormal. It is normal behavior of the camera app. If you dont touch the screen or dont take any photos it shuts down automatically to save power.
My device does not turn off while in the camera after 30 seconds.
maybe stamina mode off? or any other battery saving apps
Actually,with stamina on it still does not turn off the camera after 30 seconds.
Same here it wont turn off at all when u are using the camera!
@senhor wrote:
It doesn't close when you are using, if you don't do anything and leave camera app on it shuts down after 30 secs
well I just tried it again I left the camera on for more than 2 minutes and the screen did not turn off!
@senhor wrote:
Not the screen turns off, just the camera shuts down. And stamina doesn't effect anything.
Anyway I solved the problem. If you open camera with camera button it shuts down after 30 secs because it might think you opened camera accidentally. But if you open camera from launcher it doesn't shut down.
Oooo didn't know that lol , you are right it shut down after 20 or 30 sec I guess ...
Yes,that is true.If you go through the app,it does not turn off.
