I am having problems with calls not connecting!
I have also been in touch with my network to see if it is them and am still awaiting reply...
Whenever I dial out, I just get the single 'beep' and the call does not connect.
Anyone else having this problem?
That does seem like a network issue, or your SIM card its probably acting up
hi, I'm having this issue - did you literally just clean the sim card? As in physically remove dirt? Thanks
