I will forward this feedback internally.
Hi
Today i update my Xperia Z1 with current relaease of Andorid update version(14.4.A.0.108). but i didn't get any improvement in Call log detail. Still i am getting the multiple record for same mobile number in call log. My suggestion please move all call log for same number under one detail means if i click on call detail for any number then i can get all call record for that number with in one detail section.
Hi Sony Developers,
Are you looking over this issue. Can I suppose to be solved this issue in any next update.
I have the same issue... I have multiple calls from X person from different days and some calls are grouped together and some are appearing multiple times as a single log.. First i thought that has to be a logic in that sorting, but I suppose there is any, is just a issue.
The normal behavior in my opinion if I have missed received or outgoing call from the X contact then all entries should be grouped all together for that contact and different contacts should be sorted chronologically (like conversation from the SMS view)
I have version 14.4.A.0.157 (4.4.4)
The issue is still present in lollipop. Duplicate entries of the same call..
Hi Samuel, Was this issue forwarded to the devs? The call log is a mess, i can't find nothing in it because of the issue . I have only a few persons in the log and the entries are so many that is very confusing. The same contact reappearing over and over again and sometimes appearing a few times grouped together..
I've change my Z1 with an XZs and the call log behaves the same. What is going on !?!?! Is this a bug or a feature. I cannot find any patern on how the call log groups the calss
