Had real problems yesterday with Bluetooth - NFC doesn't seem to work, had problems getting the phone to search for bluetooth devices, only way I could get it to work was to repeatedly turn the Bluetooth off & on - Won't pair with a sony BT (SRS-BTV5) speaker at all. Had problems pairing with smartband 2 and smartwatch 3, Smart band 2 will not stay connected.
Customised DE full wipe.
I'm sorry to hear that
Do you still see this and have you also tried to restart the phone? I tried pairing with SRS-BTV5 here using NFC but i couldn't find anything wrong.
The SmartBand 2 may have connection issues if there's any other downloaded app that uses Bluetooth Low Energy (BLE). I'm afraid i currently don't have any other solution than to uninstall other apps that uses BLE.
Hi Rickard,
I've done 2 factory resets and full wipes with both Customised DE MM and Customised Nordic MM, I'm about to send you the log files I've collected
