When connecting a Sony SBH-20 Bluetooth Headset to my Z1 Compact there is no sound when Bluetooth voume is set to 1. I need to raise it to 2 for the sound to be output and then it is too loud for me when listening to music.
SW version in mobile is 1.4.4.A.0.108
I have also tried with a Jabra Play BT headset with same result.
Update: Now I have tried with a Sony SBH80 and then it works ! Step 1 on the volume does output sound and on a reasonable level when playing music.
For the SBH20 and Jabra Play the problem persists, but to be clear the in-call volume works fine on all steps, it is the Media/Music volume that is silent on step 1. It also seams that step 10 does not give any increase for Media on these two headsets. SW error ?
Hey,
Aha ok, well then it's like you said; a Sony Xperia related problem..
Either way it's pretty bad that a basic volume function behaves like this on a flagship smartphone (I'm using z3).. :p.. it's 2015
@fitli65 wrote:Hi Quester
As I have a Xperia Z Tablet, I only have Clear Phase in my Sound Settings!
I disabled it... No change in behavior...
The removing and pairing again in Bluetooth I already tried... Same problem...
Thanks
David
One user with Xperia Z3 did it and worked for him, He unpaired, restarted, then paired again. Try with a restart in between and check.
Still the same!
The first level is to loud!
Looks like there are not enough stages of volume!
I hope for a system update from Sony!
Kindly try this last thing: Go to Settings -> Apps -> All -> Audio settings -> Clear data, unpair your speaker, restart phone, pair again and test.
Did this too... Still the same...
Hey,
It's not going to work. This needs to be developed and improved by Sony techs.
I am of the same opinion :smileysmileywink:
I tried this and it worked (using a Z1 with JBL Flip 2). BUT the next time I used the speaker the volume went back to being to loud again... The speaker works very well with a Galaxy S3 and Nexus 5.
Is there any proper solution in sight or any app that might solve the problem?
I have nexus 5 and nexus 7 and i have this same exact problem.
android version 5.0, 5.1, 5.1.1 and M developper preview 1&2.
It seems to me not an xperia problem.
I have Sony SBH20 handsfree.
Maybe the problem is handsfree and not phone?
Hi!
I think it is a bit unnessesary, but this kind of app solved this instant for me
https://play.google.com/store/apps/details?id=opotech.finevolumev2&hl=en
Not sure what is causing it, but a 3rd party app helpedme to get the volume to the proper level.
I have experienced this quite many times, as I have several BT headsets and speakers ... annoying ...
/L
