Recently i have been facing this problem that my Bluetooth turns off in seconds after connecting to another device. This is a huge obstacle in using my Gear . I tried connecting in a safe mode with the same result. Maybe its new Android update. Please help me solve this problem asap
I did that and it shows no problem
Do you have any other device that you can pair to? do you have stamina mode on?
I don't have my stamina mode on and i tried with 4 Bluetooth devices. It connects for 2 seconds and then disconnects
I did all the test and everything is fine. Clicked accept solution by mistake.
I'm having the same problem, did all the tests and the Bluetooth problem is still happening.
My Bluetooth constantly turn off, My SmartWatch cant be conected all the time, I need to turn on again and again several times. All the test of Bluetooth pass withoout problem. I dont know what else to do
I have same problem.
