Battery optimisation disables automatically
Ashish_Saini
Hello..
In marshamallow the battery optimisation option disables itself automatically.After updating it was working fine but around 2-3 days later.I've noticed that it disables itself not only during charging but also normally.Please address this issue.
profile.country.RO.title
_alexdon_
Nevermind, it will always revert to not optimized if you go back from that screen.
alexdon
9 REPLIES 9
@Ashish_Saini
could you elaborate, perhaps add some screenshots
Ashish_Saini
As you can see in the image it says "NOT OPTIMISED" and when i change it to "ALL APPS" . It automatically reverts to "not optimised".
sgizmo
To me too but i think this is normal. Is this really doesn't work?
JOHN_f
I can't see your screenshot but It is normal that when you enter battery optimization,shows not optomizes apps.If you change It to optimized it sould be ((not optimized)) If you enter again.
Ashish_Saini
@ JOHN_F
But I think it was working when I updated to marshmallow. Do you own a z2?.Can you check that please.
_alexdon_
You didn't have doze before, you only had stamina and battery saver that is default.
alexdon
Ashish_Saini
@ alexdon
Sorry. I can't understand you.
_alexdon_
alexdon
Ashish_Saini
@ alexdon
So you are saying that it's totally ok. Thanks.
