battery less life in a while
Tonic79
Hello, After nougat everything was so perfect to not believe. Battery consumption was incredibly little, and I used the smartphone for about two months. I don't know, from the night to the day, the battery changed behavior, and now it goes down to about 50% without doing anything special. Why?
3 REPLIES 3
profile.country.PH.title
MarlonUk1
try to search "BATTERY DRAIN" , there are lots of threads that have possible cause and solutions that might help you out. use the search bar above
devilek87
After update 4 days  ago i got big baterry consumption
Tonic79
Sorry but the problem is not what to do in order to reduce the consumption, but what is the reason why from the Paradise I'm in from the night to the morning! Is that a degradation of the battery? Can it be a service that is running in the background? Do I really need to do a factory reset? Or is a common problem of nougat? Thanks
