Backup Problem - Freeze
Kiu_RO
Android 6.0.1
Starting about two-three weeks ago, i've noticed that automatic backup on SD Card is not working.
Backing-up Applications freeze always at 50%.
I tried a back-up via Xperia Companion, i choose only 'Settings' and 'Other', and somehow 'Other' is freezing.
What can be the cause? How can I investigate?
Kiu_RO
Problem solved! (08.01.2017)
Launching Xperia Companion, i have updated to last version (1.9.2.0), and try to backup only Other, like usually update failed, but this time indicating me the application causing the failure.
I have uninstalled the app (My Vodafone in my case), and after that i successfully made a full backup of everything both on Sony Device (using standard backup app) and using Xperia Companion.
So, thanks Sony for the update of Xperia Companion, nice job!
7 REPLIES 7
Emil
Enthusiast
Hi @Kiu_RO,
I'm sorry to hear this. Slightly_frowning_Face
It sounds like there is something in your device that cannot be backed up if it only works when you don't include the other category. I have requested more information regarding what is included in the Other category, I will let you know when I know more. Slightly_smiling_Face
When you do a backup to your SD card, have you tried to uncheck the box for apps? Does the same thing happen then?
Kiu_RO
Is something very strange...
Last successful backup on SD Card, was on 12.09, all items checked
(i have scheduled automatic backup at 7 days, and starting from that time, nothing successfully).
Always at Applications, at 50% freeze.
Unticking Application check-box, create the backup with no problems.
I've tried to unninstall some apps, trying to imagine what app i have installed after 12.09, but it's more like a "guess" process, not something correct.
I don't know how to investigate at that percent 50 in fact what app is causin the freeze.
Or, do i have the possibility with a third app to investigate the exact date when a new app was installed. I'm thinking to try to disable all apps installed after that date, and to see if this solve the freeze problem at 50%.
Any help on this matter is really appreciated!
Thanks
Kiu_RO
Very strange situation: i also try to manually create a backup, only 'Applications', and i've changed the location, this time online account, not SD Card. The backup freeze from begining at 0% (not 50% as in the situation of SD Card)...
What could be the reason, is something behind blocking this...?
Kiu_RO
I accidentally discovered another thread similar with this, and sad to say, was marked as solved, but NONE of the solutions / ideas proposed there are in fact working... Slightly_frowning_Face
/t5/Xperia-Z3/backup-on-each-file-stops-at-50-precislely/td-p/1146888/page/3
Emil
Enthusiast
The Other category performing a backup using Xperia Companion is simply all other applications that are not included in the first categories. This includes any third party application installed on the device that supports Backup & Restore.
If you experience that the backup fails when Other is selected you can try the following.
  • Make sure that the software of your Xperia device is updated.
  • Unmark the Other category and try again.
  • Once this failure has happened, the device must be restarted before retrying, otherwise it is going to continue to fail any kind of backup.
Kiu_RO
I followed your instructions, still no changes.
Backup is freezing, either on phone or via Xperia Companion...
Kiu_RO
